Documentation for Users
2.0.6
Perception Toolbox for Virtual Reality (PTVR) Manual
Before putting your HTC Vive Pro headset on, here are a few steps to follow...
(image from Pascal Wiederkehr, CC BY-SA 4.0, via Wikimedia Commons).
Compatibles headsets: Up to april 2025, PTVR has been compatible and tested only with HTC VIVE Pro headsets (no eyetracking) and with an HTC VIVE Pro Eye (with eyetracking) or HTC VIVE Pro 2 (without eyetracking).
See VIVE Pro Series.
NOTE: From May 2025, PTVR is also compatible and tested with Metaquest 1, 2 and 3 ! ( see next section for details).
Literally everything you need is very clearly explained here in the VIVE Pro Eye support or here to get their user guide in pdf format.
You will thus learn quickly how to setup the headset (figure 1), the link box (figure 2), the base stations (figure 3) and the (hand) controllers (figure 4) with figures such as those below (images from Vive site).
| Figure 1: Headset | Figure 2: Link box | Figure 3: Base stations | Figure 4: Controllers |
Software Installation
If you do not need to measure ocular behaviour (gaze position, pupil size, ...), you only have to install Steam and SteamVR to control the Head-Mounted Display - HMD. Once these softwares are installed, you can test your Head-Mounted Display (even if PTVR is not yet installed)..
If Steam is not installed yet on your PC, download it here, and install it.
If you do not have a Steam account yet, create one to be able to install Steam.
Open Steam software within which you can directly look for SteamVR software and install it.
Run SteamVR : this should open the following window (it might be hidden in the Windows task-bar):
Figure 1:. | Figure 2: . |
Note the icons in the bottom bar (from left to right: headset, controller #1, controller #2, base station #1, base station #2) : when colored, this means that they are detected and active.
Most importantly, click on the 3 bars in the top-left corner, and you'll see all the important tasks that you can accomplish, such as the Room Calibration process see section Calibrations.
After installing SteamVR it is important to check the following:
In the Steam VR program -> go to Settings -> go to OpenXR tab,
and check that you get the same as in the following image.
The first line should contain "Current OpenXR Runtime:" SteamVR.
This section has been updated on 20. October 2023 !
There are two recommended options to install the eye tracking software:
Note the line with the robot's head which indicates that the eyetracking software (Vive Sranipal) is installed.
Clicking on this line will launch the eyetracking software.
The two options presented above are summarized with important additional information in this Vive web page.
This important page is reproduced below (retrieved on 20. october 2023).
The important point to note in the figure above is that the OpenXR option is now strongly recommended so that future PTVR developments will aim at replacing the current Sranipal eyetracking software by the OpenXR approach.
*The System Tray is another name given to the Notification Area, which you can find in the right-side of the Windows Taskbar. The System Tray features different types of notifications and alerts from your computer like your Internet connection, or the volume level.
Eyetracking Troubleshooting (for installation and use) See Vive developer's page
